Forums >> Revit Building >> Technical Support >> Using Studio Max models
Mon, Mar 27, 2006 at 8:00:55 PM | Using Studio Max models
cadjockey
Hi all, We are trying to create an element to be used in a very organic shaped roof. The element is a corner piece to a thatched roof. Refer attached image. We are able to create this element in Studio Max and export the image as a dwg. However, revit doesn't seem to like the dwg. My goal is to create this shape as family where I can nominate a number of cord lengths (the length of the hip rafter it will sit on) I a fishing for ideas/solutions. Any imput is appreciated. cadjockey
Tue, Mar 28, 2006 at 1:55:53 AM | RE: Using Studio Max models
cadjockey
Hi All, I have been able to create a grass roof using solely revit. This is what I have so far. refer attached. The corner pieces can be adjusted to the desired hip rafter length and pitch. cadjockey Post edited on 2006-03-28 01:56:08
Tue, Mar 28, 2006 at 2:24:54 AM | RE: Using Studio Max models
cadjockey
Hi all, You will notice that the corner pieces are fillied with a number of lines. This is the result of creating them using a segmented sweep. Is there are way to remove these? cadjockey
3D Studio Max 7 data exchange problem
Wed, Apr 20, 2005 at 2:29:13 AM
3D Studio Max imported into Revit?
Tue, Jul 24, 2012 at 6:22:10 AM
3d Studio Max
Wed, Apr 7, 2010 at 12:25:38 PM
Importing from 3D Studio Max
Fri, Jan 8, 2010 at 10:00:38 AM
Exporting from Revit and into 3D Studio Max
Wed, Oct 31, 2007 at 1:25:11 AM
Page generation time: 0.1071
