Forums >> Community >> Newbies >> Topo Surface Pattern
Tue, Jul 14, 2015 at 3:31:05 PM | Topo Surface Pattern
coastalclimbing
Is there a way to accomplish this yet? Going through old posts and it doesn't seem like there is a viable method in the program.
Tue, Jul 14, 2015 at 4:30:47 PM | Topo Surface Pattern
Your question is not clear.  Below is a topo with a concrete block material.  As you can see, it has a surface pattern.
So I assume you mean a 2D or 3D linework pattern.   This is not supported.
Tue, Jul 14, 2015 at 7:57:10 PM | Topo Surface Pattern
coastalclimbing
Yes this is what I mean. There is still no way to apply a hatch pattern to a toposurface in plan view? The last thread i read about this was from 2013 and wanted to be sure there was not some easy workaround.
Thanks
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:58 PM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
placing a street, vegetation and barrier or railing on topo surface
Tue, Jan 17, 2017 at 5:47:40 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Page generation time: 0.1954
