22 Users Online (20 Members):
Forums >> Community >> Newbies >> Sunpath sizing
Is there a way to make the sunpath less than 100% as it to large for my project?
2 things:
- Sun path is based on view size so use a section box to limit your view.
- Now if the view is smaller, click on the Sun path in the view and change the sun path size back to 100% for that smaller view.
I shrunk my section box however the sunpath remained the same size even after enabeling the "fit to model" button. This is on a 2d plan view.
If you re-read my post, I said nothing about fit to model. I SAID "...click on the Sun path in the view and change the sun path size back to 100% for that smaller view...." If the properties of the sun path say 100%, then that is the smallest you can get for the view you have established.
When I adjusted the section box the solar path adjusted for the 3d view however not for the 2d plan view. What bounds the solar path in a plan view?
Plan view is still somehow dependent on overall model but I'm not sure of how that is controlled.
Can you use your 3D Scope view set to the plan orientation?
I dont think so.
Read this HELP.
This is where I went to first and it doesn't tell me what the solar path is bound to on a plan view. I can't go below 100% and I am trying to get it to fit on my site plan.
2d/3d description arrows, sunpath families |
Sun, Apr 27, 2014 at 7:47:58 AM
Pipe sizing in Revit. |
Tue, May 6, 2014 at 7:00:56 AM
Revit 2013 - MCWS Pipe sizing |
Wed, Jan 23, 2013 at 10:29:46 AM
Duct |
Mon, Dec 7, 2009 at 2:19:55 PM
Actual Columns with proper sizing?? Where do I get these? |
Fri, Mar 25, 2016 at 8:30:21 AM
