19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Can't devide window top reveal (can't apply material on outside reveal)
Hi,
I want to apply different material on all outside window reveals. I figured out that side window reveal can be devide by "closure line" which is in window family, and when i wrap walls at insert. However nothing happens with top reveal...
Please see attachment
(Revit 2016)
Edited on: Fri, Jul 10, 2015 at 4:45:15 AM
Correct, closure settings for wraps doesn't work at the head.
You can paint this surface in the model.
You could also provide a thin material here in the window family.
If anbody else has a solution, I would like to hear it.
Thanks for reply!
"You can paint this surface in the model." what do you mean paint it in the model?
This is actually what I want to do... To paint that part from exterior
Goto a 3D view and spin the model so you can look up at the bottom of the window head then use the paint process to apply your material. NOTE! Paint is only a 3D surface change. It does not change the representation of the material in section/plan views.
Parameters that don't act to constrain |
Fri, Feb 2, 2007 at 10:37:01 AM
Wall's surface pattern goes through the reveal in elevation view |
Thu, Jul 12, 2012 at 10:46:52 AM
13
REVEAL QUESTIION |
Wed, Mar 9, 2005 at 5:07:49 PM
Wall Reveal Material? |
Wed, Sep 3, 2008 at 3:32:19 AM
Wall Reveal 'surface material' is incorrect |
Thu, Aug 10, 2017 at 4:13:52 PM
