22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> model in place issue
is there any way to rotate an extrusion perpendicular to its original workplane?
I'm trying to create a domed roof with several ridge lines running vertically down it and thought the easiest method would be to create an extrusion, then create a radial array, but it won't let me do so due to the work plane being from the side and needing to rotate in a top down view.
revit 2016
thanks
We might be able to give you a better process if we knew a little more about your shape. It sounds like you created your extrusion from a elevation or section view? And then are trying to array that from a plan view, is that correct? Are you trying to array the shape while still in the in-place family editor or did you finish the form and then try to array it?
Yeah that's pretty much the case ( I prefer to work in 3D but aligned the view to an elevation and plan respectively). I am trying to array while still in the editor as the family includes other pieces of stonework that I do not want arrayed
Well, again, without knowing much about the shapes you are using and the end-product you want, we can't suggest much on your process. I will say that your work plane is part of the problem as well as working from 3D views. After developing your first form, set the work plane to a plan plane before you try to do the array.
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass |
Thu, Sep 27, 2012 at 7:05:36 AM
Create a new family from a 'model in place' |
Tue, Jan 17, 2017 at 12:57:22 PM
Display issue in Revit 2014? |
Mon, Aug 24, 2015 at 10:43:06 AM
Model In-Place |
Tue, Jan 26, 2010 at 3:23:39 PM
