Forums >> Revit Building >> Technical Support >> Splitting gridlines
Mon, Mar 27, 2006 at 3:51:42 PM | Splitting gridlines
MrCampy
Does anyone know how to split a gridline in a building so that the center unnecessary portion does not show? It is just visually annoying to have the gridlines running all through the building. I would prefer them just to be at the bubblehead and come 5 feet or so into the building.
Mon, Mar 27, 2006 at 3:57:39 PM | RE: Splitting gridlines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is possible with sections but i don't believe its possible with grids... A workaround would be to create a line pattern that has a really huge spacing between dashes. As revit will always start and finish a line pattern on a dash this should effectively achieve what your after... Or if you don't want end line, make the line white...
Mon, Mar 27, 2006 at 4:08:57 PM | RE: Splitting gridlines
MrCampy
Thanks, I will try that, it makes sense.
dimensioning gridlines
Sat, Nov 4, 2006 at 10:27:59 AM
Gridlines
Fri, Aug 8, 2008 at 3:24:08 PM
Building Gridlines vs Underground Gridlines
Thu, Mar 17, 2011 at 1:49:59 PM
re-numbering gridlines
Wed, Mar 26, 2008 at 3:08:06 PM
Gridlines in front of Model / Linework
Tue, Jul 13, 2010 at 12:45:01 PM
Page generation time: 0.0260
