Forums >> Revit Building >> Technical Support >> Dot Region Pattern
Thu, Jul 2, 2015 at 10:38:16 AM | Dot Region Pattern
jtebok
Hi all,
i want to make a region fill pattern that is the same as the dot hatch in revit. (Evenly spaced dots)
I found this online, but I don't know where or how to create custom hatches in revit.
Revit structure 2016
Thu, Jul 2, 2015 at 10:46:27 AM | Dot Region Pattern
jtebok
Same as the dot hatch in autocad* sorry
Thu, Jul 2, 2015 at 10:47:18 AM | Dot Region Pattern
jtebok
This is what I found, what do I do with it?
ShinyOTS,A series of dots;%TYPE=MODEL0, 0, 0, 0.79375, 1.5875, 0, -1.5875
Thu, Jul 2, 2015 at 10:59:15 AM | Dot Region Pattern
jtebok
So I added this as a .pat file, but there is nothing in the region
Thu, Jul 2, 2015 at 1:03:48 PM | Dot Region Pattern
jtebok
Okay so, after a figured out who to make these crazy things. I made two for your guys to use.
I don't know if there is a way to scale the region once it is in revit, like you can do in CAD, so I made two, one is half of the other.
ShinyOTS,
;%TYPE=DRAFTING
90, 0,0, 0,.25, 0.0,-.25
90, .125,.125, 0,.25, 0.0,-.25
ShinyOTS,
;%TYPE=DRAFTING
90, 0,0, 0,.125, 0.0,-.125
90, .0625,.0625, 0,.125, 0.0,-.125
Fri, Jul 3, 2015 at 12:18:42 AM | Dot Region Pattern
hugh
3.5 Stars: 4 Votes
You can scale while loading the pattern to Revit.
Be aware that "dots" will be converted on loading to very short lines consistent with Revit's minimum line length.
Zoom right in to gauge the effect.
Hugh Adamson
www.hatchkit.com.au
Tue, May 2, 2017 at 11:23:26 PM | Dot Region Pattern
EllynC
Hi JTebok,
why am I not able to import it in revit?  Says No "Drafting"type patterns found.
Thanks.
Tue, May 2, 2017 at 11:38:12 PM | Dot Region Pattern
hugh
3.5 Stars: 4 Votes
Check that there are no leading spaces on lines within the.PAT file.
Hugh Adamson
www.hatchkit.com.au
Wed, May 3, 2017 at 6:24:42 AM | Dot Region Pattern
Must be saved in a simple txt format with the PAT extension.
dot pattern for hatch
Thu, Jul 17, 2014 at 7:59:18 AM
Howdy! I'm new!
Wed, Apr 14, 2010 at 1:29:56 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
Blank filled Region
Fri, May 2, 2008 at 12:30:12 AM
Site Sub Region Surface Pattern
Thu, May 7, 2009 at 1:23:33 PM
Page generation time: 0.1690
