Forums >> Revit Structure >> Technical Support >> Line thickness in detail family
Wed, Jul 1, 2015 at 5:53:43 AM | Line thickness in detail family
Profiil
I have a problem with matching line weigthts in detail item families.
I created new line type in detail item family (thickness 2 which is set 0.2 mm in 1:20 scale) When i bring it into my project it is about 0.35mm which was set as a default.
I am unable to change the thickness.... when i put it 1mm then it still goes around 0.35mm. Other thing is when i randomly open it, it seems to forget that i set the new line style from 3->2 and the thickness in line weights are reset again (forgot the new system i set them).
What could be the problem.
Wed, Jul 1, 2015 at 6:56:19 AM | Line thickness in detail family
The project rules!
In Revit, lineweights are controlled in two ways.  For both annotative (includes detail) is object styles.  Second for model elements is line weight chart adjustment per view scale.  VG can alter object style settings.
Changing lineweights in families like detail elements doesn't typically do anything because the category is already set in the project VIA object styles.
Wed, Jul 1, 2015 at 7:07:05 AM | Line thickness in detail family
Profiil
But how am i able to change it? i have already set same settings in both, family and my project.
Wed, Jul 1, 2015 at 7:09:56 AM | Line thickness in detail family
Profiil
Ahaa.. i understand what you meant.. I was changing line style when i actually had to change object styles->detail items.
Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM
Line thickness display when doing batch family update
Wed, Jan 17, 2007 at 12:01:22 AM
Wall line thickness
Mon, Sep 26, 2005 at 5:47:35 PM
Topo Cut Line thickness
Tue, Feb 14, 2012 at 10:49:24 AM
View Title Line Thickness
Thu, Jan 24, 2008 at 1:42:39 PM
Page generation time: 2.0143
