24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> room dimension tag
hi all
is there such a thing that coudl be made?
a tag indicating max length (X,Y) of a room?
eli |
No way to do this. The room only reports area.
2 Posts No Rating |
A room will report the perimeter, so there may be some work arounds you could use-
This post is older, from Autodesk forums:
http://forums.autodesk.com/t5/revit-architecture/tutorial-parametric-room-size-label-family/m-p/2654285/highlight/true#M42559
Here's an add-in from Case, Inc. that may help you map the information into a tag.
http://apps.case-inc.com/content/free-migrate-parameter-parameter
try this one.
its another beauty from daryl g.
just drag the points to the wall and value adjusts.
cheers
0 Posts No Rating |
Is there a way to make this tag display to the nearest inch instead of fractional inch?
0 Posts No Rating |
thanks; do you have imperial room tag?
www.be.net/designw |
hi
i found this very useful in the end
a family that will reduce the reading as per your definition
enjoy
eli |
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
How to add and edit an annotated dimension and room tag |
Sun, Apr 11, 2010 at 8:30:30 AM
room tags to show dimension |
Mon, Oct 21, 2013 at 7:33:24 AM
