Forums >> Revit Structure >> Technical Support >> wall & beam join
Tue, Jun 30, 2015 at 9:10:20 AM | wall & beam join
Husseinedrees
it seems like when ever i try to join (structural wall) with Beam both maretial are conrete , i cant manage to join them , they tend always to interference with each other , knowning that the beam is curved
how to fix??????
Tue, Jun 30, 2015 at 11:14:46 AM | wall & beam join
Something is wrong in your process.
Here is a structural wall with a structural beam - both the same material.
Tue, Jun 30, 2015 at 5:56:50 PM | wall & beam join
Husseinedrees
yes i kn if they are the same structural material they should auto-join , but i am talking about if u draw the beam CURVED , with arch line three points , or with spline shape and try to join it with a wall
Tue, Jun 30, 2015 at 8:46:29 PM | wall & beam join
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Curved and spline work ok as well.
Can you upload your file with the beam and the wall in question only?
Wed, Jul 1, 2015 at 4:29:46 AM | wall & beam join
Husseinedrees
one side is well connected the other side is not!!! , for me i think it is some kind of a BUG , because all this is the only frame i have this problem with in the whole project up-tell now
Edited on: Wed, Jul 1, 2015 at 5:08:53 AM
Thu, Jul 2, 2015 at 8:49:21 PM | wall & beam join
Husseinedrees
i fixed it , it was a REVIT BUG , by time i closed-open revit again and just like magic the Beam is able to join the wall , after i checked (material are the same), all process&parametars are in the right way they joined Smile
beam join command
Sun, Dec 23, 2012 at 11:50:10 PM
beam and wall connection
Mon, Nov 23, 2009 at 12:24:04 PM
Beam in wall (2009)
Wed, Mar 18, 2009 at 12:46:20 AM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:54 PM
Beam/joist going through wall
Thu, Sep 11, 2014 at 4:32:00 PM
Page generation time: 0.7350
