Forums >> Revit Building >> Technical Support >> Sheets Title Blocks
Mon, Jun 29, 2015 at 11:46:12 AM | Sheets Title Blocks
GLKIRK
Sheets  Title Blocks
I guess they are one in the same?
I have only used the 11x17 sheets.
I now need to use the 24x36 size.
Seems the one that comes in Revit 13 is 22x34.
Is this the right one?
Thank you very much!
Mon, Jul 6, 2015 at 1:57:14 PM | Sheets Title Blocks
marscreature
4.5 Stars: 3 Votes
The main reason people use 22x34 titleblocks is because it scales perfectly with 11x17. 22x34 titleblocks are fine on 24x36 paper (just double check your print scale so a "scale to fit" doesn't mess up any scale on the drawing(s))
The main reason 24x36 titleblocks are used because people want the most out of the 36" rolls of paper they have.
There isn't necessarily a "right" one to use unless a project or company requires one or the other.
Mon, Jul 6, 2015 at 2:30:16 PM | Sheets Title Blocks
There should be several titleblocks available but if you don't have the correct size, then edit one to make it be correct.  Only scale the print output when you print to a down-sized sheet.
revit 2018 manipulate the title block or sheet
Wed, May 30, 2018 at 2:11:37 PM
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:00 PM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Customize new Title Blocks
Mon, Sep 21, 2009 at 2:55:19 PM
Title blocks
Mon, May 11, 2009 at 2:53:44 PM
Page generation time: 0.1766
