Forums >> Revit Structure >> Technical Support >> BEAMS JOINING COLUMNS problem
Sat, Jun 27, 2015 at 10:08:18 AM | BEAMS JOINING COLUMNS problem
Husseinedrees
cant manage to make a good fit joining between 1 column and 6 TIE beams as u see in the picutre , i used modify tan-->geometry panel--> beams/columns joining tool , it help me with (3 beams)+(1 colum) , but when i reached this case (6beams)+(1column) it doest seem to be able to fix it
Tue, Jun 30, 2015 at 7:41:51 AM | BEAMS JOINING COLUMNS problem
Husseinedrees
mmm look like this is going to take for over here , any way i have reached the solution for it dont bother
1)it was using the joints tool -->geometry panel--> modify tab
2) i changed the structural material , inside editing family , and that fixed alll
Can't select beams nor columns
Sun, Mar 10, 2019 at 10:12:36 PM
Walls and Structural Beams/Columns and Finishes
Tue, Jul 19, 2016 at 3:46:11 PM
12
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:19 PM
Bracing not joining beams ;(
Thu, Oct 27, 2011 at 11:21:43 AM
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:11 PM
Page generation time: 3.9784
