Forums >> Revit Systems >> Technical Support >> drafting view from model view
Fri, Jun 26, 2015 at 12:32:34 PM | drafting view from model view
gregroberson
gregroberson Avatar
There used to be a subscriber tool that let me convert my model view (section, #D, elevation . . . whatever) to a drafting view inside my revit project.  I cannot find this anywhere or a convenient way to do this.  Any ideas?
Greg
Fri, Jun 26, 2015 at 1:38:15 PM | drafting view from model view
It was in the extensions/tools area called freeze drawing.   If you don't have it, you can do the same thing manually.   Just export to CAD then import.   The problem with all CAD imports is if you explode them, you have a lot of junk.  I advise you to import in a scrap project, explode there, then change everything to your standards.
Fri, Jun 26, 2015 at 5:04:47 PM | drafting view from model view
gregroberson
gregroberson Avatar
I AM AN AUTODESK SUBSCRIBER, BUT CANNOT FIND TH EXTENSION.  DID THEY GET RID OF IT?
GREG
Mon, Jun 29, 2015 at 7:27:31 AM | drafting view from model view
I could not find anything new on it.  I suggest you ask on the autodesk subscription site.
Model view section cut refer to a drafting view
Wed, Nov 13, 2019 at 5:44:08 AM
Converting Model Views to Drafting Views
Fri, May 13, 2016 at 2:13:29 PM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
Using a callout on a drafting view
Fri, May 16, 2008 at 10:39:58 AM
Page generation time: 2.3199
