Forums >> Revit Building >> Technical Support >> Component visibility in elevations
Fri, Jun 26, 2015 at 9:41:50 AM | Component visibility in elevations
dbegalske
Probably something simple, but I can not spot the problem.
I inserted a wall pack light on the East Elevation of a model, works just fine. Went to insert the same wall pack on the South Elevation and Revit reports that none of the components will be visible. Even more annoying, if I switch back to the East Elevation, the wall pack on the south side is visible.
Any ideas what I'm missing? Using Revit 2015.
Thanks,
David
Fri, Jun 26, 2015 at 10:13:01 AM | Component visibility in elevations
Compare your VG settings and also your view's discipline in these two views.
Visibility of downloaded component
Wed, Jun 5, 2013 at 3:49:42 PM
component visibility in different plan views
Wed, Sep 19, 2007 at 10:44:53 AM
REVIT CONTENT - problem with velux family
Wed, Nov 10, 2010 at 5:22:23 AM
Datum Extent Visibility
Mon, Nov 12, 2007 at 3:28:18 PM
Visibility of component acting up
Wed, May 7, 2008 at 4:59:08 PM
Page generation time: 4.3624
