Forums >> Workflow & Implementation >> Training >> Layer Modifier for duct and Pipe tags
Fri, Jun 26, 2015 at 1:13:41 AM | Layer Modifier for duct and Pipe tags
juliuspepito
4 Stars: 1 Votes
Hi all, anyone has done layer mapping using layer modifiers in revit? They are working great as far as our company required for Revit to CAd conversion. However, some category has very limited modifier available. Ant idea if we can add? Our company requires to use different layers for the tagging on each pipe or ducting system type.
Like the layer modifiers for Annotations (especially the duct and pipe tags) are very limited. The modifers available are only as follows: {Costum 1}{Costum 2}{Costum 3}{Underlay}{View Type}{Workset}...NO System Type
Is it possible to add modifiers on these. what i se {Workset} modifier is useless because annotation cannot be allocated in a specific or user-defined workset.
Appreciate anyones advice on these.
thanks in advance.
Fri, Jun 26, 2015 at 1:31:23 AM
exporting revit to cad issue- duct and pipe fittings converted as blocks
Wed, Jun 17, 2015 at 1:58:55 PM
Layer Modifier AIA Revit 2013
Mon, Dec 23, 2013 at 12:10:35 PM
Pipe sizing in Revit.
Tue, May 6, 2014 at 7:00:56 AM
Duct Tags - Airway
Tue, Sep 6, 2011 at 9:04:46 PM
Page generation time: 2.3093
