Forums >> Revit Building >> Technical Support >> Copy/Monitor and IFC
Thu, Jun 25, 2015 at 3:05:37 PM | Copy/Monitor and IFC
Terranky
Does anyone know what method Revit uses to monitor objects during the Copy/Monitor process? I assumed it was the GUID of an object, but through testing I concluded this is not true.
As background, I am trying to link an IFC file either by opening, saving as an RVT and linking the RVT file in, or by using the new 2016 functionality of linking with the ability to make objects room bounding and host elements. Revit often thinks objects have been deleted, including levels and grids. Sometimes I have success moving a wall and Revit recognizing it, but more often than not the wall has lost its monitoring association (the copy/monitored wall is still monitor something, just not the wall it's supposed to be). It seems like Revit shuffles around whatever ID it is using to track objects.
Please let me know if more information is required. It's a difficult query to explain. (Revit 2015 and 2016)
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Rev Arch 2009 conultants elelments in copy monitor
Wed, Aug 31, 2011 at 2:21:36 PM
Page generation time: 5.3033
