Forums >> Revit Systems >> Technical Support >> Lutron lights won't turn on
Tue, Jun 23, 2015 at 11:16:49 AM | Lutron lights won't turn on
chollon
I have put these lutron lights in my drawing and they won't turn on when I render. I have selected interial: artificial only. What am I doing wrong?
http://seek.autodesk.com/search/finire?source=SearchBox&locale=en-us&resetft=true
Edited on: Tue, Jun 23, 2015 at 11:17:28 AM
Tue, Jun 23, 2015 at 12:23:02 PM | Lutron lights won't turn on
Please start by reading the similar threads below.
Thu, Jun 25, 2015 at 9:08:14 AM | Lutron lights won't turn on
chollon
It looks like the light isn't cutting the ceiling. How do I fix that?
Thu, Jun 25, 2015 at 9:23:32 AM | Lutron lights won't turn on
It is a face based family.   Edit the family to include a void that cuts the host.   I suggest you create the void off to the side and set it to cut the host then edit the void sketch to the correct location.
^^ Good learning process.
Mon, Jun 29, 2015 at 10:11:26 AM | Lutron lights won't turn on
chollon
I made a quick void to see if it would cut the cieling and it won't. Do I cut it in the ceiling plan?
I selected "cut with voids when loaded."
Mon, Jun 29, 2015 at 10:28:56 AM | Lutron lights won't turn on
When you work on a hosted family, the host is shown like a cube.   Your void has to go down into the cube, not above it.  When you create the void, you have to tell it to cut .... pick... the host.
Lights won't turn on for exterior render
Wed, Mar 16, 2016 at 6:03:04 PM
Sconces direct from Lutron won't light up
Tue, Nov 21, 2017 at 3:33:56 PM
interior rendering, lights won't come on
Thu, Apr 25, 2013 at 10:42:56 AM
Lights not acknowledged?
Thu, Jun 23, 2011 at 7:03:41 AM
Ceiling Lights don't self-illuminate
Mon, Oct 17, 2011 at 10:21:44 AM
Page generation time: 1.9195
