Forums >> Revit Systems >> Technical Support >> Help rotating a family
Mon, Jun 22, 2015 at 2:51:57 PM | Help rotating a family
chollon
This light fixture is upside down and I can't figure out how to rotate it to make it not upside down.
I have attached my building I would like to use the lights in.
I am using Revit 2012.
http://seek.autodesk.com/product/latest/agg/lutronelectronics/Lutron-Electronics/LutronFinireSquareAdjustable
Mon, Jun 22, 2015 at 2:54:13 PM | Help rotating a family
This is a face based family.   Did you try placing the light in a reflected ceiling plan?  That is how you should place all ceiling lights.
Mon, Jun 22, 2015 at 2:56:58 PM | Help rotating a family
chollon
I am very new to Revit. Nothing shows up in my ceiling plans. I have attached the file.  Why does nothing show up in my ceiling plans?
Mon, Jun 22, 2015 at 3:04:30 PM | Help rotating a family
You have not attached any files, you only attached a link in your first post.
Use a reflected ceiling plan and do you have a ceiling?   It needs to be on in VG and so does lighting.
Mon, Jun 22, 2015 at 3:08:49 PM | Help rotating a family
chollon
Yes, I have a cieling. What is VG? How do I turn it on/off? I don't know why the file didn't attach.
Edited on: Mon, Jun 22, 2015 at 3:10:09 PM
Mon, Jun 22, 2015 at 3:32:40 PM | Help rotating a family
You need to spend some time with your HELP:
ceilings
VG
and some beginning tutorials.
Tue, Jun 23, 2015 at 8:43:15 AM | Help rotating a family
chollon
I now have a ceiling plan and it is visible, but I can't place any lights. I get the error, "Couldn't find an appropriate Host.  Try selecting a different Host Face or switch Placement Mode." All the tutorials I read say to go to the Link's VG settings, but I don't have that tab. I wish I could post my file!
Tue, Jun 23, 2015 at 8:45:40 AM | Help rotating a family
chollon
The other lights will place, just not the Lutrons.
Tue, Jun 23, 2015 at 8:54:38 AM | Help rotating a family
I downloaded the family and placed it on my ceiling - no problem.   It is face based as I said so from a RCP, you pick 'place on face' tnen a spot on your ceiling.
Tue, Jun 23, 2015 at 8:58:35 AM | Help rotating a family
chollon
Thank you. I had "place on vertical face" not "place on face" selected. It is working now. Thank you for your patience!
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Viewports without rotating title
Wed, Apr 22, 2009 at 10:52:58 PM
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Page generation time: 5.9242
