18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Transparency when printing
2 Posts No Rating |
Hi,
I am having problems with printing both to pdf and hardcopies. We are are working on an expansion project and typically for these projects we would place a transparent solid grey hatch over existing building floor plans. When I do this in Revit it appears as I want on screen but when printed the filled region loses its transparency and obliterates the linked CAD file behind. The below screenshots might show the problem better.
I am also experiencing this issue with some of my families. If I have symbolic lines above a Detail Component whch contains a filled region, it will appear correctly on screen but the fill jumps to the top when printed.
We are using Revit 2015 Update Release 8.
Thanks in advance for any solutions
P
You will probably not get this to work the way you like. A couple of options you can try.
- Pick the hatch - over-ride graphics in view - set to halftone. You can also adjust transparency.
- I like to set all of my existing components to halftone.
Vector printing and rasterized transparency |
Thu, Jul 25, 2013 at 4:59:33 AM
Transparency not printing |
Wed, Jan 14, 2015 at 12:47:54 PM
Fill Region set to Transparent but printing Opaque [ 1 2 ] |
Sat, Jan 26, 2019 at 12:16:15 AM
17
Basic Wall as Curtain Wall panel transparency incorrect. |
Wed, Nov 23, 2011 at 9:37:16 PM
Structural floor transparency |
Wed, Jul 27, 2016 at 1:28:48 PM
