Forums >> Revit Building >> Technical Support >> Grass thatched roof
Mon, Mar 27, 2006 at 12:40:30 AM | Grass thatched roof
cadjockey
Hi all, How would I go about creating a roof type that is made of grass? Just like Gilligans Island. The resort I am working on at the moment uses a roof type call 'Alang Alang'. It's pretty common in the tropics. How can I create this in Revit? cadjockey
Mon, Mar 27, 2006 at 1:00:51 AM | RE: Grass thatched roof
eldados
eldados Avatar
4.5 Stars: 8 Votes
your question relate to structure or hatching? I would just create it as a normal roof with hatch pattern for surface and cut. if you are talking about the shape, do a roof by extrusion... am i answering anything here? Smile
Integrator
KarelCAD
Mon, Mar 27, 2006 at 1:49:33 AM | RE: Grass thatched roof
cadjockey
Hi eldados, The roof is quite an organic form. See attached image. I am able to create a simple sweep revolve however, only as perfect circle. You'll notice the humps on the corners. How would I do these? cadjockey
Mon, Mar 27, 2006 at 2:13:40 AM | RE: Grass thatched roof
eldados
eldados Avatar
4.5 Stars: 8 Votes
just create the roof like you normally do, you can easily create this roof, than all I'll do is host sweep fascia, create a profile to suite you and apply...
Integrator
KarelCAD
How would you model this thatched roof?
Wed, Aug 16, 2017 at 7:38:39 AM
roof help!!!
Wed, Feb 11, 2009 at 5:21:56 PM
HOW CAN I MAKE THE GRASS LOOK MORE REAL.
Wed, Nov 26, 2008 at 9:13:41 AM
Grass rendering
Sun, May 15, 2011 at 8:12:26 PM
rendering grass
Tue, Apr 17, 2012 at 4:09:40 PM
Page generation time: 1.1794
