Forums >> Revit Building >> Technical Support >> linked dwgs missing
Fri, Jul 9, 2004 at 7:52:22 AM | linked dwgs missing
kshawks
I have linked some autocad drawings in my project and when i opened the file this morning the links were missing. when i try to re link them i get the following message: "at least one instance of this link already exist it can be invisible because the links unloaded. continuing will create another instance for this link." what has happened and what should i do?
Fri, Jul 9, 2004 at 1:58:30 PM | RE: linked dwgs missing
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
were the linked files moved or deleted?
Fri, Jul 9, 2004 at 5:13:01 PM | RE: linked dwgs missing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you said you tried re-linking the files did you go to the file menu and choose manage links and reload them from there or did you trying importing the file again and linking it? It sounds like you tried the latter. Use the manage links menu to reload the dwg or re-locate the file if its moved. Cheers, Chris.
Wed, Jul 14, 2004 at 7:02:37 AM | RE: linked dwgs missing
Bimman
Bimman Avatar
1 Stars: 2 Votes
i get the same message when i move the files and have to reload them. to do that follow mr spot's info.
PWD
Tue, Nov 26, 2013 at 2:46:26 PM | linked dwgs missing
fae9heh
I have the same problem, except I`m working on a local file of a Central file. I tried all the above steps. None worked! I even deleted the CAD link from the Manage tab in the Central File, but I still can`t reload, unload, or even link any other file to my Revit files !
Tue, Nov 26, 2013 at 3:13:20 PM | linked dwgs missing
Not enough information to help.  This process works when done correctly.  Read your HELP - search links.
What Revit?  Do you have all the updates installed?  Don't just say yes.  Look under the ? / about.
ARe you in a plan or what?
With central files, the linked file can't be on your remote system.  It should be in the same location as the central.
Are you working in a workset that is turned off in the view you are in?
Wed, Nov 27, 2013 at 7:49:03 AM | linked dwgs missing
fae9heh
I`m working on a local file in Revit Architecture 2013. All the linked files are in the same location as Central file. Below is all the steps I did:
- Made a copy of one of the linked CAD on my desktop ( as a future refrence) and saved another CAD file instead of the original linked CAD. > It didn`t show up in the revit after few attemp of unload, reload, checking the VG settings, ..
- cut the copy version of CAD file from my desktop and replaced it with the original one. This time not only that CAD file but all my other linked CADs are not showing
-I checked the visibility settings, turning on the workset working on in both my local file and central file.
- Now it doesn`t even link ANY other CAD.
Thanks for your help in advance Smile
Sending a file with Linked DWGs in it
Mon, Apr 9, 2012 at 12:04:53 PM
Draw order of linked DWGs
Thu, Jun 21, 2007 at 9:14:00 AM
Imported DWGs not exploding?
Tue, Feb 8, 2005 at 9:11:31 PM
On / Off Function for layers linked/inserted from DWGS
Mon, Mar 28, 2005 at 8:59:30 PM
Globally shut off electrical outlets in plan view only in Arch dwgs
Mon, Jan 4, 2016 at 6:36:57 AM
Page generation time: 8.4019
