Forums >> Revit Building >> Technical Support >> Water mark not translucent
Wed, Jun 17, 2015 at 8:30:54 PM | Water mark not translucent
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hi Guys do you know how to make a watermark apprear behind the views placed on a sheet. I have the text on the A3 family page and set to translucent but it is covering the drawings see attached. Anyway of changing this?
Revit 2018........
Thu, Jun 18, 2015 at 7:01:38 AM | Water mark not translucent
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
sorry never had the need to do it this way.
I would normally place the text as Red and place it across the titlesheet titleblock, not across the whole sheet.
Thu, Jun 18, 2015 at 7:36:51 AM | Water mark not translucent
Your image doesn't show it covering anything.
When you say behind, you mean you want your model elements on top of this text?  Might work for walls but what happens with a floor then?  It would hide it all.
Annotation lines are typically on top.
Thu, Jun 18, 2015 at 6:45:12 PM | Water mark not translucent
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Sorry that was in family editor.
Please see below of a view of the worksheet showing the text even though it is translucent, it is over the top of everything.
It only will go behind the windhow schedule. Goes over the top of plans and legends.
Edited on: Thu, Jun 18, 2015 at 7:18:01 PM
Revit 2018........
Fri, Jun 19, 2015 at 8:30:18 AM | Water mark not translucent
The translucent setting is only for the text background - not the text.   Sorry.
Tue, Jul 14, 2015 at 9:08:06 PM | Water mark not translucent
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey WW hoping you or someone can help with this one.
I have drawn a preliminary legend using a translucent hatch (took a while)
It shows as it should in plan but when I print or pdf it goes over the top.
In print setup it is on colour even when I change it they all end up the same.
Revit 2018........
Thu, Jul 16, 2015 at 6:24:11 PM | Water mark not translucent
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
bump....
Revit 2018........
Thu, Jul 16, 2015 at 7:03:37 PM | Water mark not translucent
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
See this. I have never tried Steve’s suggestion though. I’m still using Acrobat for that.
Mon, Jul 20, 2015 at 1:01:44 AM | Water mark not translucent
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I tried that one and got this result. :-(
I ended up making it a fill region and putting it on individually....
Edited on: Mon, Jul 20, 2015 at 1:52:34 AM
Revit 2018........
Casting shadows with translucent objects?
Wed, Sep 2, 2009 at 3:51:37 PM
Translucent polycarbonate facade
Wed, Apr 2, 2014 at 4:06:07 PM
modeling body of water (2017)
Fri, Mar 3, 2017 at 10:19:37 AM
Translucent Existing Phase after Rendering
Sun, Sep 28, 2014 at 7:08:34 AM
Translucent Filled Regions
Tue, Dec 13, 2011 at 7:34:31 AM
Page generation time: 1.3980
