Forums >> Revit Building >> Technical Support >> Family Types Issue
Tue, Jun 16, 2015 at 5:44:16 AM | Family Types Issue
jamesm2505
I have created a custom window family with several types but all the types end up being the same when loaded into a project, and dependant on which type was active in the family editor last. Can anyone explain why this is happening / how to fix it?
I'm pretty new to (semi-)parametric family creation so it may well be something stupid that I've missed.
I have attached the relevant family, and the misbehaving parameter is the height.
Using Revit architecture 2015
Thanks
Tue, Jun 16, 2015 at 9:23:10 AM | Family Types Issue
Something must be corrupted in that family.
I started a new family from the 2015 template with just the opening and it functions correctly so I know the template and Revit is not the issue.  You may have done something in your process to corrupt this system parameter but I don't see it.
Start again and as you develope the family, test it often.
Tue, Jun 16, 2015 at 10:09:51 AM | Family Types Issue
jamesm2505
Thanks, WWHub, I'll give it another shot
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:50 PM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
Family types problem.
Tue, Apr 21, 2009 at 10:00:20 AM
Major issue in Family Default Type setting
Thu, Nov 23, 2017 at 8:48:09 AM
Family re-load
Tue, Dec 29, 2009 at 7:39:53 AM
Page generation time: 4.2025
