Forums >> Revit Building >> Technical Support >> Issues while making PDF
Mon, Jun 15, 2015 at 7:12:14 PM | Issues while making PDF
jdespo
Hey guys
Having an issue with a sheet not being able to print without it freezing
Been playing around with it for a while and worked it out that when a "solid fill transparent Filled region" is inlcuded in
the print the whole prgrame freezing at %62 and doesnt move from there...
If i hide the region the page prints within seconds
If i change to region settings to Opaque, Revit prints the page to PDF no issues :/
Any ideas what i can do next?
Tue, Jun 16, 2015 at 4:12:32 PM | Issues while making PDF
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
1) Delete region, redo region, purge model, remove all warnings, audit and detach model.
if no then,
2) Delete region, redo region but make two or more regions instead of one.
if no then,
3) Delete sheet, create new sheet.
if no then,
4) Delete view/s and create new ones.
good luck
Thu, Jun 18, 2015 at 1:15:36 PM | Issues while making PDF
Ranger57
I use pdffactory pro, never had a problem with it.
Wed, Jul 1, 2015 at 2:22:27 AM | Issues while making PDF
jdespo
Still cant seem to PDF to page with a tranparent Filled region
Still testing a few options, when i crop the view to show only a quater of the site it seems to work :s
any other ideas ?
Running out of ideas and shouldnt be this hard, same process we have used over multiple projects
Thu, Dec 3, 2015 at 10:27:15 PM | Issues while making PDF
jdespo
Bringing back this issue.. still having problems trying to create a PDF when a Soild Filled Filled Region is shown in the page, Only causing issues in new projects. We have tried copying from old projects and still cause a delay in creating the PDF. can sometimes take 20min to create the PDF. A 3m x 3m Soild filled Region box is adding 4mb to a 1.5mb File as well  ... any other advice?
Fri, Dec 4, 2015 at 7:23:57 AM | Issues while making PDF
It may be the PDF writer you are using.
Is this a solid fill or a very tight linework hatch (maybe imported from CAD)?  That could explain the problem.
Wed, Jan 13, 2016 at 4:31:00 PM | Issues while making PDF
jdespo
So i made some tests with a trial version of bluebeam and works fine. Just weird Adobe is slow to PDF on certain pojects, but fine with others
Revit PDF printing issues
Mon, Jul 19, 2010 at 11:40:53 AM
Wall Solid Fill Cut Pattern Jagged on PDF
Fri, Apr 3, 2015 at 10:36:32 AM
Printing issues
Thu, Nov 4, 2010 at 7:32:11 AM
yet another issue with roofs
Wed, Jun 10, 2009 at 9:14:58 PM
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale.
Tue, Sep 6, 2011 at 7:51:06 AM
Page generation time: 1.2395
