Forums >> Revit Building >> Technical Support >> Help help diagnosing double door with adjustable swings
Thu, Jun 11, 2015 at 3:22:20 PM | Help help diagnosing double door with adjustable swings
DavidLarson
I made a double door with adjustable swings that is having all sorts of problems.  The family flexes properly until I put it into a project.  Then it acts erratically when I adjsut the different swing arcs past 90 degrees.  Sometimes it'll work at 135 degrees, sometimes it goes wonky at 91 degrees.  It is not consistent.  The door will also shift it's position along the wall when I flex the swing arcs.  Again it is not consistent when it fails.If somebody can tell me what is wrong with it I'd appreciate it.
Do you even Revit bro?
Thu, Jun 11, 2015 at 3:35:52 PM | Help help diagnosing double door with adjustable swings
First, you don't tell us what Revit so I won't even try.
Please read all of the similar threads below.
creating double door with multiple swings
Fri, Oct 31, 2014 at 1:44:28 PM
adjustable double door
Tue, Mar 27, 2007 at 10:23:28 AM
creat double door w/ adjustable swing
Mon, Apr 27, 2015 at 1:30:05 PM
Thanks for adjustable door swings, but
Tue, Feb 6, 2018 at 3:33:07 PM
45 degree door swing for Double Doors
Wed, Apr 11, 2007 at 9:56:41 AM
Page generation time: 0.6234
