Forums >> Revit Building >> Technical Support >> Calculated Values in Room Tags
Fri, Mar 24, 2006 at 4:03:27 PM | Calculated Values in Room Tags
pdoele
I am trying to get the calculated value of Occupant Load into a custom Room Tag for a Life Safety Plan. I can get the proper calculated value result in a room schedule, but I also want to display that result in the Life Safety Room Tag I have generated. When I insert a label into my custom Life Safety Room Tag (derived from the basic room tag), I can only access shared parameters, but no calculated values. Any ideas?
Sat, Mar 25, 2006 at 8:31:59 AM | RE: Calculated Values in Room Tags
TomDorner
4.5 Stars: 25 Votes
Can't be done at present. It has been a wish list item for years. The best you can do is do the calculation in a schedule like you are doing, add a shared parameter to your room tag, and in the schedulewith both columns side by side hand fill in the room tag parameter for occupancy load. With an advanced kwolege of the Revit API this may be able to be automated by a savy programmer, but I'm not at that level yet. HTH Tom
Wed, Aug 16, 2006 at 1:27:45 PM | RE: Calculated Values in Room Tags
kshahan
Any luck on developing this yet..I'm working on the same problem. Would like to have a tag for occupant load calcs. would be cool to have this automated. Let me know if you have found a way to work this. I'll check out your file. Thanks, K
Fri, Feb 8, 2008 at 2:58:39 PM | Calculated Values in Room Tags
hroark
It's 2008, and I'm in the same situation.  In order to control the various values for Occupancy Load Factor, I have created a key schedule that holds the Occupancy type  and Occupancy Load Factor.  I have calculated the Occupant Load (number of persons) in the room schedule with a formula (Area/Occupancy Load Factor).
I would very much like to display this calculated value in a room tag for the Life Safety Plan without having to create a shared parameter and manually enter the Occupant Loads.  I want the tag to show Room Name, Number, Area, Occupancy type, and the Occupancy Load (calculated value).
Any hopes of getting this in the upcoming release of Revit 2009?
Wed, Jun 4, 2008 at 5:49:59 PM | Calculated Values in Room Tags
eyeeye
<<fast forward to Revit 2009>>
Coming across the same problem now.  Is this available yet in Revit 2009? I can't seem to make it work.
Fri, Sep 11, 2009 at 3:36:54 PM | Calculated Values in Room Tags
pepsiqueen
pepsiqueen Avatar
WELL, we are now to revit 2010, as far as i can tell this is still not possible, which totally blows! does anyone know otherwise?
I'd rather be riding at whistler. or highland. thats good too.
Tue, Jan 25, 2011 at 5:38:02 PM | Calculated Values in Room Tags
pepsiqueen
pepsiqueen Avatar
make that 2011 and i am back around to this same annoying problem!
Wed, Mar 30, 2011 at 10:47:17 AM | Calculated Values in Room Tags
stack24
stack24 Avatar
I'm having the same problem.  Seems like it should be so simple.  I feel like if I could get into the room family to add the calculation there it might work.  I don't yet know how to access the room family.  I think it's untouchable.
Wed, Mar 30, 2011 at 11:12:48 AM | Calculated Values in Room Tags
pepsiqueen
pepsiqueen Avatar
yeah, as far as i can tell they are untouchable. its excessively annoying!
Wed, Mar 30, 2011 at 4:08:03 PM | Calculated Values in Room Tags
thetabest
thetabest Avatar
3 Stars: 2 Votes
I want to help here, I used Revit back in 2008 & 2009 to do Occupancy calcs.  While I understand that you aren't able to show the parameter that you want in your tag, have you considered creating a shared parameter which will show in your tag, and then in the schedule assigning to this parameter the value which you see in the schedule?  Then turn this shared parameter to an invisible field...
The linchpin lies in whether or not you can set the shared parameter to equal the existing value, but if so, then you've automated the process and could save time.
GL
Edited on: Wed, Mar 30, 2011 at 4:09:59 PM
Trent Best
Best Systems
the.tabest@gmail.com
using schedule keys, shared parameters and calculated values in schematic design
Tue, Mar 6, 2007 at 1:41:36 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Making a Room Tag that will show a Calculated Value from a Room Schedule.
Tue, Jan 25, 2011 at 5:32:37 PM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
length in beam tag
Wed, May 23, 2012 at 7:27:00 AM
Page generation time: 0.4925
