Forums >> General Discussion >> Revit Project Management >> Project Phases
Wed, Jun 10, 2015 at 10:30:17 AM | Project Phases
my74porsche914
I am working on a facilities model that has many projects within it. 1 of the jobs is not going forward and I need to delete it and all its contents. How do i do this?
I see there is a combine function, I see does get rid of the phase but moves the objects (walls etc...) onto the phase you combined it with
Wed, Jun 10, 2015 at 11:08:44 AM | Project Phases
You somehow need to isolate the elements in that job.   Did you use worksets originally to seperate these?  That would make this easy now.   Just isolate the workset and delete the elements (or maybe move them to a design option for future use.)
Are these in a phase that is seperate from the other elements?   If so, then set the views to that phase and only show new then do the same as above.
If you did not plan ahead, then I guess you have to pick the items individually.
3D View of Phases
Thu, Feb 24, 2005 at 5:51:44 PM
How to show all new phases as new
Fri, Mar 7, 2014 at 11:59:09 AM
Ghost Phases
Mon, Mar 24, 2014 at 5:08:46 PM
12
use a model from a complete project for a new project - updating phases
Wed, Feb 27, 2019 at 2:00:41 PM
Construction Phases
Mon, Jun 30, 2014 at 8:32:26 AM
Page generation time: 0.4563
