18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Section Title View deleted can not recover
Hello
Thought this would be an easy fix. Before I realised that its a no no, I deleted the view title in one of my section views (i think I did a left click delete) now all my section views have disappeared and new sections I create do not have the title. After a search I find that it refers to view port but since I ony have section properties which does not refer to view title or veiw port. my view port or titile view it no longer exists unless someone knows of a way to recover it. Not sure why deleting one view has removed all and new section titles.. Had a look in view visibility, it is not available to turn off/on.
Hope someone can guide me..
Regards
Craig
I don't believe you did what you think you did because you can't delete a view title on a sheet.
You need to tell us more.
All good just found out view ports only visible in sheets. Now fixed
Cheers Craig
Trash Folder for deleted views |
Mon, May 14, 2007 at 8:04:31 AM
I accidentally deleted my elevation views.. help please |
Sun, Oct 22, 2006 at 8:41:23 AM
recover unsaved files |
Mon, Jul 12, 2010 at 9:52:58 AM
Viewport title for sections |
Thu, Mar 22, 2007 at 10:04:17 AM
original title section changes when duplicated view is created on a new sheet - |
Fri, Mar 13, 2015 at 10:17:47 AM
