Forums >> Revit Building >> Technical Support >> Selecting Things I Can't see
Thu, Jun 4, 2015 at 5:52:28 PM | Selecting Things I Can't see
arqrivas
Hi everyone, I'm wondering why Revit does this, when I'm working in any view (mostly in elevations and sections) and try to select with a markee Revit Will select things that I can't see because they are behind any object (wall, furniture, etc.) or they are out of the reach of any crop region but somehow related with what I can see in the view (and sometimes not related). It does not select thing from the floor below because is in another view.
Is there any setting that I can set to fix this or anything I can do? Cause this is really annoying and I have erase or move things by mistake and did not realize until later.
Thanks.
Edited on: Thu, Jun 4, 2015 at 5:53:29 PM
Thu, Jun 4, 2015 at 6:01:46 PM | Selecting Things I Can't see
arqrivas
Here are two images where you can see more clear what I mean
Edited on: Thu, Jun 4, 2015 at 6:02:24 PM
Edited on: Thu, Jun 4, 2015 at 6:03:03 PM
Thu, Jun 4, 2015 at 6:03:54 PM | Selecting Things I Can't see
arqrivas
Here is the other pic, for some reason I couldn't upload them together
Thu, Jun 4, 2015 at 6:32:40 PM | Selecting Things I Can't see
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Check the elevation/section view far clipping. Everything within the view extends can be selected. Pull back your far clipping window so it doesn’t protrude into the adjacent room, beyond the wall.
Fri, Jun 5, 2015 at 7:10:52 AM | Selecting Things I Can't see
I try to teach all of the folks in our office to as a habit, do exactly what pijpiwo says.   Not only to reduce the problems you encountered but also to better the performnace.   Wit views that are set deeper than necessary, Revit has to 'hide' elements.   Not much of an issue now as it was when we had to set the 3 GB switch but why be sloppy?
Fri, Jun 5, 2015 at 9:34:18 AM | Selecting Things I Can't see
arqrivas
Ok, so that is. Is a wear behavior but that's ok, I'll try to pull back the far clipping the most I can to avoid that.
Thanks!
Selecting-De-selecting objects.
Fri, Nov 25, 2005 at 10:12:01 PM
Not selecting what´s behind
Wed, Apr 8, 2015 at 7:59:10 AM
Interior Elevation Adjustments - things just aren't showing up!?!
Wed, Jan 7, 2009 at 9:18:12 AM
Selecting/Finding Specific Level
Thu, Aug 7, 2014 at 8:57:04 AM
Highlight when selecting
Wed, Jun 29, 2011 at 4:05:28 PM
Page generation time: 1.7808
