Forums >> Revit Building >> Technical Support >> A 360 Syncing Problem RAM 100%
Tue, Jun 2, 2015 at 4:05:27 PM | A 360 Syncing Problem RAM 100%
ScubaMan
Revit 15 Update Release 8
Computer:
CPU - Intel i7 950 3.07GHz
Ram - 24 GB
Hard drive - 500GB STAT 6gb
I have been syncing no problem up until the last hour. The project is rather large and typically takes 1-5 minutes to sync to the cloud. Other people working in my office on the same file are able to sync no problem.
When I tried to sync the last 3 times it instantly raises my ram to 100%. I let this go over lunch and it was still trying to syncing when I got back (about 1 hour). Has anyone else had a similar problem?
Thanks in advance for any help.
Tue, Jun 2, 2015 at 4:28:59 PM | A 360 Syncing Problem RAM 100%
ScubaMan
Since my first Sync failed when I reopened the file it gave me the option to open my saved local file. This last time I told it to discard all unsaved work and it now syncs to the cloud file.
My guess is that I changed something at the same time someone else did and this caused the sync fail. Our internet connection is a little slow. Could this be the colporate?
Thanks again.
Wed, Jun 3, 2015 at 4:05:50 PM | A 360 Syncing Problem RAM 100%
ScubaMan
That only temporarily fixed the problem. Had our IT guy look at it. He talked with someone people from technical support and they demined it a hardware issue.
Revit 64bit & RAM
Tue, May 4, 2010 at 9:02:19 AM
Ram Ram Ram
Tue, Jul 25, 2006 at 10:20:07 AM
Can't Remove File from BIM 360
Wed, Apr 10, 2019 at 8:59:16 AM
Ram-revit link problem
Wed, Oct 13, 2010 at 11:03:41 AM
Central File Syncing Issues
Sun, Mar 11, 2012 at 5:34:27 PM
Page generation time: 4.8862
