9 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Filter views on a sheet by revision
0 Posts No Rating |
I want to be able to filter all the contents on a sheet based on a specific revision, when i create a revision cloud it hides the cloud only for that specific revision but not the drafting view or plan, I want to be able to filter it all without having to hide even on intergrated text. I thought about adding a parameter that appears throughout all elements so I can select which revision. Is this idea possible so it can appear in every text or family? Thanks. any ideas are welcomed.
Your question is not clear.
How do you want to filter a view by revision? Do you mean not show the revision or worse, the view? Obviously no way! It's called use an earlier PDF made without the revision.
0 Posts No Rating |
I mean a hide objects but when I hide objects I can set a revision it belongs to. And select Revision 1 or Revision 2 and different hiddent elements appear or disapear.
Sounds more like you are looking for design options to me.
You can't assign an element to a revision. Revisions are annotative and they do not control the model.
Hiding a Revision in the Revision Schedule |
Thu, Nov 21, 2013 at 3:04:51 PM
Revision editing |
Wed, Sep 3, 2014 at 3:31:46 AM
REVISION TAG AND SCHEDULE |
Sun, Jul 20, 2014 at 3:09:52 AM
Revision Clouds and tags on Sheets or in Views? |
Wed, Jan 20, 2016 at 9:36:23 AM
Current Revision Date in sheet index |
Mon, Nov 2, 2009 at 11:22:28 AM
