Forums >> General Discussion >> Revit Project Management >> Wall Properties
Tue, Jun 2, 2015 at 11:09:57 AM | Wall Properties
revitdeco
Hello,
I am trying to update my model of an existing building which has lead paint in it.  I want to highlight these walls seperately (using filters or color schemes) by creating an Instance Project Parameter.
My only problem is that I need the parameter to be specific to a certain side of the wall.  CryingInterior vs exterior, or have the ability to click and select that type of wall).
Any thoughts?
Thanks,
Rick
Tue, Jun 2, 2015 at 11:13:05 AM | Wall Properties
revitdeco
Sorry, I don't know why it put in that stupid face.  It was just supposed to be a parenthesis.
Tue, Jun 2, 2015 at 12:55:59 PM | Wall Properties
You could 'paint' a different material on that wall face.
Tue, Jun 2, 2015 at 1:01:32 PM | Wall Properties
revitdeco
Can materials be assigned parameters?
Tue, Jun 2, 2015 at 1:18:01 PM | Wall Properties
revitdeco
Nevermind, figured it out.  That is pretty handy, thanks for the help.
Tue, Jun 2, 2015 at 2:04:32 PM | Wall Properties
revitdeco
Only problem with using the material method and painting the walls, is that I can't sort or override the graphics by materials.  At least, I can't figure out how to do that if it is possible.
"inherit properties" when starting a wall
Wed, Jan 19, 2005 at 4:36:36 AM
System Wall Properties
Wed, Mar 18, 2009 at 12:55:04 AM
Wall Properties and Groups.
Thu, Dec 10, 2009 at 12:31:07 PM
Architectural column accepting wall properties but not sweeps
Thu, Jun 12, 2008 at 2:03:06 PM
Wall type properties not showing in section Revit Architecture 2012
Fri, Jul 5, 2013 at 9:17:46 AM
Page generation time: 0.6455
