Forums >> Revit Building >> Technical Support >> Topo material color not showing?
Mon, Jun 1, 2015 at 4:14:48 PM | Topo material color not showing?
buttonsrtoys
1 Stars: 1 Votes
I inherited a project with a topo may that has a subregion. The topo's material is "Grass" and the subregion is "Asphalt". The color of their shaded values are set to green and gray. Neither color is showing up when the visual style of the view is set to shaded or any other setting that shows color, or when the view is rendered photorealistically. They both show as the same color gray.
As a sanity check, I opened another project and changed the material settings and they rendered as expected, so as far as I can tell, I'm not doing anything silly. I also checked the VG settings and there aren't any overrides.
Is there something else I should be investigating?
Mon, Jun 1, 2015 at 7:00:53 PM | Topo material color not showing?
buttonsrtoys
1 Stars: 1 Votes
Never mind. Newb mistake. Topo was created under Existing phase and the views were New Construction so everything existing was rendered gray.
Thu, Nov 26, 2020 at 11:24:41 AM | Topo material color not showing?
T0mmh4s
Hey, could you please reply to me, how to fix this exact problem? I came accros the same problém and dont know how to solve it. Thanks a lot.
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Align material with toposurface to achieve accurate elevation and contour?
Wed, May 1, 2013 at 1:12:29 PM
material not showing in render.....plz help
Sat, Jul 2, 2011 at 5:44:27 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:01 AM
Page generation time: 1.4885
