Forums >> Revit Building >> Technical Support >> Base Extension Distance + Wall Sweep (at base)
Mon, Jun 1, 2015 at 2:52:21 PM | Base Extension Distance + Wall Sweep (at base)
justjames
Aloha All,
Using Revit '14.
I am attempting to create a wall type as seen in the attached pdf. Currently, I have enabled Base Extension Distance on the outer most exterior wall layer (EIFS). The problem I am having is when I apply the sweep, whether in the family type itself, or after I place said wall, Revit prompts me with the "Could not create integral wall sweep for wall instance. Sweep position is outside of its wall. Please check sweep parameters" error.
I understand the error, but I'm seeking an alternative way of achieving the wall type without having to create a EIFS sweep.
Much mahalos,
Justin
Tue, Jun 2, 2015 at 6:51:03 AM | Base Extension Distance + Wall Sweep (at base)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How tall is that EIFS band?  I would do this as a stacked wall or if it is just a small band at the top of the wall I would use the Wall Sweep tool under the Architecture Tab>Build Panel>Wall pulldown>Wall:Sweep
Tue, Jun 2, 2015 at 7:14:18 AM | Base Extension Distance + Wall Sweep (at base)
justjames,
I think I understand your problem but I have not tested.  Please explain furthur.   Is your wall layer pulled down or up from the base of the wall?
Wed, Jun 3, 2015 at 1:39:50 AM | Base Extension Distance + Wall Sweep (at base)
justjames
teafoe5,
The EIFS band extends from 3' from the base all the way up to the second story. I would not advise using a wall sweep for a layer of a wall that jogs up and down around ornamention on the building facade.
WWHub,
I created the EIFS layer by unlocking the base constraints in the wall type's structure dialog box (section view). As I am sure you know, I then typed in 3' in the instance parameter for Base Extension Distance. That is all good and well, however when I do apply a wall sweep that is the GFRC Wainscot, it gives me the error. Likewise, if I add the sweep to the Wall type's structure, and then type in 3' in the walls instance parameter Base Extension Distance. I hope this added some clarity WWHub!
Wed, Jun 3, 2015 at 7:55:50 AM | Base Extension Distance + Wall Sweep (at base)
The GFRC you add as a sweep needs a host.   You want the host to be a sub-layer of the wall.... sorry - you can't do that.
Use teafoe's suggestion of a stacked wall with the bottom having the GFRC and it ends at 3' where the EIFS faced wall starts.
Wed, Jun 3, 2015 at 6:26:49 PM | Base Extension Distance + Wall Sweep (at base)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Just a thought, ...instead of base extension offset, you can try applying a sweep (GFRC), and a reveal to cut EIFS. However, the wall layer behind the reveal will adopt the surface pattern of the layer being cut/removed by this reveal.
Wall Joins Disappear When Base Extension Distance Parameter Not Zero
Wed, Oct 12, 2016 at 3:26:45 PM
Wall Base Offset... one works, one doesn't. Why?
Wed, Jun 10, 2015 at 2:53:52 PM
editing wall sweep base
Mon, Apr 30, 2007 at 10:41:14 AM
Adding quarter round moulding to existing base board moulding
Tue, Nov 20, 2007 at 8:43:48 PM
Adding wall base
Thu, Aug 31, 2006 at 10:44:34 AM
Page generation time: 3.3542
