Forums >> Revit Building >> Technical Support >> Handrails Flatten When Extended
Fri, May 29, 2015 at 12:31:26 PM | Handrails Flatten When Extended
tbryanm
1 Stars: 1 Votes
Can anyone explain why my handrails flatten when I try to extend them past the top or bottom riser.
I have poked around all of the property settings and nothing.
Thanks
Fri, May 29, 2015 at 1:11:10 PM | Handrails Flatten When Extended
What Revit ?   We ask that you ALWAYS include that because it affects our answer.  I will anser based on 2013+ .
You say handrail - not railing so I will answer about the handrail.   Because the handrail is controlled seperately from the railing, uou can include an extension definition differently on each end.   The problem is that this was still the old code where the extension at the bottom is flat.   So, you can't use this option.    Instead, you have to sketch the extension from an elevation or section view.
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
Rvt 2013 Handrails for 3-run stair
Wed, Apr 5, 2017 at 1:59:55 PM
non-continuous handrails
Mon, May 20, 2013 at 3:10:42 AM
Revit 2013 Stairs/Handrails
Thu, Feb 14, 2013 at 7:27:18 PM
Revit and Timberline Estimating Extended
Thu, Mar 8, 2007 at 3:07:28 PM
Page generation time: 0.8680
