Forums >> Revit Building >> Technical Support >> New Rebar Parameters in Revit 2016
Thu, May 28, 2015 at 7:48:51 AM | New Rebar Parameters in Revit 2016
FrankYYZ
I am having a problem with the new parameter Host Count.
I have 7 identical beams (Host count = 7)
Each beam has one set of ties with 9 Ties in the set
Each Beam has 6 main bars
On My Rebar Schedule I have the Parameters:  Host Count, Count, Quantity
For the Ties Revit returns the values 7, 7, 63  - this is correct
For the main bars Revit returns the values 7, 7, 42 - this is correct
I want to add a calculated field Number of Bars in Each Beam
The Formula is Quantity / Host Count
For the Ties the result should be 63/7 = 9, but Revit returns 7
For the main bars the result should be 42/7 = 6, but Revit returns 0
To try and find out what Revit was doing I changed the formula
Formula: Quantity + 1
For the Ties the result should be 63+1 = 64 , but Revit returns 70 (this is Quantity+Host Count)
For the main bars the result should be 42+1 = 43, but Revit returns 84 (this is Quantityx2)
Other variations of this formula produce equally odd results
Could some one explain this behavior?
Thanks
Frank
Revit 2016 - Rebar note
Wed, Jul 29, 2015 at 9:21:12 AM
Rebar Visibility
Tue, Aug 11, 2015 at 3:35:53 PM
REBAR SCHEDULE HELP!!!!!!!!!!!!!!!!!!!!
Thu, Oct 4, 2012 at 6:15:25 AM
Details from 2015 messed up when loaded in 2016
Fri, Nov 20, 2015 at 3:15:52 PM
Rebar placement in concrete pedestal not allowed
Tue, Aug 30, 2011 at 10:11:16 AM
Page generation time: 1.7038
