20 Users Online (18 Members):
Forums >> General Discussion >> Revit Project Management >> Problem with text fonts.
0 Posts No Rating |
Hi!
I have a problem with a text font that I want to ad to Revit 2015.
The text font is Penumbra that is a True Type Font, I've installed it on my PC and everything works, I can use the font in word. But when I want to use it in Revit it dosent apear in my text list.
Is it someone that knows how to solv this probleme?
Thanks!
/Erik
If I remember correctly, dragging and dropping the file into my font directory didn't work. I had to install it. The system help says: "...Right-click the font you want to install and click Install."
0 Posts No Rating |
I installed it by right click on the file and choose intall, so I dont think the intallation is the probleme in this case.
Thank you for your answear!
Something else must be wrong. Even Autodesk says this;
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Installing-and-uninstalling-new-font-types-s.html
0 Posts No Rating |
This is probably you installed the font twice or multiple times.
I've encountered the same problem when developing my fonts.
Try this:
1. Reboot your computer.
2. Run "Command Prompt" as administrator.
Type: cd %windir%/fonts
del penumbra*
3. Open the Registry.
4. Look for the penumbra key and delete it under
\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts
5. Press F5
6. Reinstall the penumbra font
Fonts For Revit |
Mon, Oct 8, 2007 at 8:19:03 AM
How to Change Fonts Globally??? |
Wed, Apr 27, 2011 at 10:06:04 AM
Why I cant change Dimension fonts? |
Thu, Aug 10, 2017 at 11:51:39 AM
Text style that I can't get purge |
Wed, Sep 5, 2012 at 8:40:41 AM
fonts |
Thu, Feb 24, 2011 at 2:57:05 PM
