Forums >> Revit Building >> Technical Support >> Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 4:15:21 AM | Setting a manual height for Spot Elevations in plan
datsmabowl
Hi there,
I have a project with a lot of 2D information, such as wall cladding and ceiling finishes, the height of which obviously cannot be read by spot elevations in plan / RCP.
I need to spot dimension my ceilings, there are a lot of varying levels. I could create a new family to mimick actual spot elevations and enter the heights manually, but is there another solution? I feel as if I can enter the height of a spot elevation anywhere I choose in section I shouild be able to do the same in plan, somehow.
Thanks for your help. Smile
Wed, May 27, 2015 at 8:03:11 AM | Setting a manual height for Spot Elevations in plan
Since ceilings are created from a level, we have a ceiling tag that reads and shows the ceiling height relative to that level.
Spot Elevations on curved walls with varying height
Tue, May 3, 2011 at 5:26:46 AM
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:14 PM
Spot Elevations In Plan
Mon, Aug 7, 2006 at 5:14:23 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:54 PM
13
REV 2009 Spot elevations
Thu, Jul 14, 2011 at 1:27:44 PM
Page generation time: 0.5801
