Forums >> Revit Systems >> Technical Support >> Parameter formulas losing calculated values
Tue, May 26, 2015 at 10:57:18 AM | Parameter formulas losing calculated values
Gyvven
5 Stars: 2 Votes
I have a number of formulas in a family and one formula keeps losing the value, the value changes to 0.00. However, if I re-enter the value of one of the calculating parameters (not even changing it) it works. I recall this happening in 2012 and earlier but I haven't come across it recently. Any ideas as to why this happens and what I can do to prevent it from happening? The problem is that it happens intermittently and the entire schedule needs to be twiddled over and over again.
Wed, Jun 17, 2015 at 2:23:19 PM | Parameter formulas losing calculated values
Pikachu123
Can you send me the family? or even snap shot of the types window?
COUNT Parameter in formulas: a workaround
Thu, Apr 10, 2014 at 6:40:32 AM
String Values in Formulas
Wed, Dec 4, 2013 at 10:38:12 PM
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Page generation time: 2.8255
