Forums >> Revit Building >> Technical Support >> Copying section cut
Tue, May 26, 2015 at 9:59:35 AM | Copying section cut
jtebok
Revit 2016,
I want to copy a section cut as annotation, not have a new section created, and keep the same referencing. I found a forum where they said to click 'reference other view', but this option is greyed out on my screen when I select the section.
I have a large apartment building where I had to split the plan views up, but both views have the same typical sections, and I want to show them the same on each view.
Thanks
Tue, May 26, 2015 at 10:48:02 AM | Copying section cut
You must select 'reference other view' before you place the section callout.
Tue, May 26, 2015 at 11:34:45 AM | Copying section cut
jtebok
Thanks
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets
Fri, Jun 27, 2008 at 12:33:38 PM
Copying Receptacle's
Thu, Jul 13, 2017 at 11:50:36 AM
Is it possible to not have the bold section cut lines
Thu, Apr 3, 2008 at 12:58:16 PM
Page generation time: 0.3758
