Forums >> General Discussion >> Revit Project Management >> COUNT NUMBERS ON FAMILY PLAN VIEW
Sat, May 23, 2015 at 6:44:50 AM | COUNT NUMBERS ON FAMILY PLAN VIEW
pleojera
pleojera Avatar
Hi, we are working on a hospital project and authorities want to see the number of the patient beds on projects. Is there any way to place a label in family which shows the number provided by me or revit itself? as far as ı know model families does not support writeable text in family plans but i will be glad if you have any suggestions. Thank you.
example attached below.
Sun, May 24, 2015 at 2:49:15 AM | COUNT NUMBERS ON FAMILY PLAN VIEW
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Open the family in the family editor and create a shared text parameter and call it say "Bed Number". Save the Shared parameter text file to your office server so everyone can access it when they open the model.
Load the family back into the model and make sure the shared parameter file is loaded too.
Now create a tag using the shared parameter "Bed Number" parameter from the furniture category ( I assume your bed family was created as this type of category). Load tag into project.
Now on a plan with your revised beds tag all beds using this new tag and go around and number the beds one by one. The "bed Number" parameter will now be able  to be scheduled and will forever be asscoaited with each specific bed and taggable.
Wed, May 27, 2015 at 5:37:58 AM | COUNT NUMBERS ON FAMILY PLAN VIEW
pleojera
pleojera Avatar
Quoting Beaucoupnice from 2015-05-24 02:49:15
It worked! Thank you very much!
Edited on: Wed, May 27, 2015 at 5:39:06 AM
Total Mark Numbers vs Total Pieces in a Schedule
Wed, Jan 14, 2015 at 1:23:39 PM
Room Tag Numbers
Tue, Jul 8, 2014 at 7:22:54 AM
11
Object Count Annotation
Fri, Feb 11, 2005 at 4:06:29 PM
how can I count areas in site plan not in a building
Thu, Nov 11, 2010 at 4:40:32 AM
Nested Family Count in Table
Mon, Jan 15, 2018 at 11:47:52 AM
Page generation time: 2.5054
