Forums >> General Discussion >> Wishlist >> Will/Can Revit export to Google Sketch-Up?
Fri, May 22, 2015 at 10:41:37 AM | Will/Can Revit export to Google Sketch-Up?
DonaldLK
1 Stars: 1 Votes
The other day i was thinking it would be nice to show others what 3d Models I can easily create in Revit.  However if one knows nothing about the CAD environment I think it would be nice to be able to let them play around in Google Sketch-Up as the program is very easy to work with (my opinion).  Also as far as i know Sketch-Up is a free program that anyone can access especially if your not a student of any kind.  All AutoDesk program downloads are free if you possess a school email account, but i dont think this is always an effective route to go for laypersons.
Please let me know if Revit ever intends to make an export compatible with Sketch-up.  As this would be bees-nees Smile Thanks
Fri, May 22, 2015 at 11:45:28 AM | Will/Can Revit export to Google Sketch-Up?
Autodesk controls Revit - not us.  I doubt that they would ever change Revit to export to skp files but id oes import them and it will export to CAD.
Thu, Jul 30, 2015 at 1:12:07 PM | Will/Can Revit export to Google Sketch-Up?
KCren
You can, but I would advise against it. The model gets very complicated. It exports a lot of layers but you will lose the textures.
Edited on: Thu, Jul 30, 2015 at 1:12:29 PM
Thu, Jul 30, 2015 at 2:20:51 PM | Will/Can Revit export to Google Sketch-Up?
CDWdavid
5 Stars: 5 Votes
Autodesk has free viewers.
http://www.autodesk.com/viewers/all-viewers
Thu, Jul 30, 2015 at 7:20:55 PM | Will/Can Revit export to Google Sketch-Up?
aramixed
The workflow I like to use goes as follows:
I got into a 3D view, I select only the Types of objects I want to export (e.g. walls, doors, stairs..etc), you can also use the filter option to make sure you've only selected what you want.
I then Isolate those categories, using the "glasses" option down at the bottom.
I then export as a DXF, making sure to leave the Isolation mode on.
When you import into SU, you have options to join the surfaces.
It's not the most native way to do it, but it has worked very nicely for me.
Best of luck.
export revit model with exact measurements
Tue, Jun 23, 2015 at 4:49:18 PM
importing sketch up files
Wed, Apr 6, 2011 at 6:59:31 PM
Revit & Google Earth..
Sat, Mar 14, 2009 at 10:58:35 AM
Sketch up
Thu, Mar 15, 2007 at 6:46:50 PM
Sketch Up to Revit
Mon, Feb 4, 2013 at 1:58:04 PM
Page generation time: 4.2590
