Forums >> Revit Building >> Technical Support >> Curtain-panels - Need to alter extents
Mon, May 18, 2015 at 4:15:21 AM | Curtain-panels - Need to alter extents
Revin
Hi all,
Pls see attached image. I have a curtain-wall, with glazed panels.
The glazed panels are offset to the outside-face of the vertical mullions; problem is that they automatically terminate where the vertical mullions are situated, leaving a large gap between them.
I cannot find a setting in any of the properties dialogues to extend  (or offset) the vertical edges of the glass panels to make the gap between them smaller (since it should be a flush-glazed system).
Also, the edge-panels need to extend past the vertical mullions to cover them completely.
Has anyone found a way around this?
Thanks in advance!
Revit 2015, btw.
Edited on: Mon, May 18, 2015 at 4:15:57 AM
Mon, May 18, 2015 at 4:59:42 AM | Curtain-panels - Need to alter extents
ronmalit
5 Stars: 3 Votes
Hi
for the glazed panel did you try to select it (just the glazing only) and edit type, enter offset value, NO? not that one?
for the edge-panels to extend, if i remember it correctly, i made 2 curtain wall type:
one is for glazing system with rectangular mullions and
one is just for the horizontal FINS.
just copy, paste to same location, change type.
Edited on: Mon, May 18, 2015 at 5:01:13 AM
** dont be mad, i dont have much... i am homeless
Mon, May 18, 2015 at 7:48:59 AM | Curtain-panels - Need to alter extents
Look at your mullion profile template - the answer is there - I put a box around it.
Tue, Jun 2, 2015 at 8:11:44 AM | Curtain-panels - Need to alter extents
Revin
Fantastic!
Thanks, WWHub.
Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:59:47 PM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:57 AM
Inserting Custom Curtain Panels Into Angle/skewed
Fri, Apr 30, 2010 at 4:50:44 AM
Curtain wall panels with an arrayed profile
Thu, Mar 13, 2014 at 3:02:35 PM
Curtain Panels
Thu, Apr 20, 2017 at 3:44:25 AM
Page generation time: 0.7344
