15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> contour labels inverted
2 Posts No Rating |
After creating a toposurface manually by points I have found that when I create a contour label line the text is inverted, that is it is upside down relative to project north. This happens no matter which way I draw the line to create the label, from top to bottom or bottom to top, and using the rotate tool makes no difference to the display. Can anyone offer advice on this?
I'm having this problem also. I wondered since this post is over a year old if anyone has come up with a solution. The contour labeling so cool. But it's frustrating since my contour labels are upside down!
The labels always read as if you are positioned on the downhill side. If you can orient your site so that higher elevations are at the top, it works great...a solution to one problem that probably creates other more important problems. I was told by a Revit expert that there is no work-around for this short of manually labelling each line yourself.
Contour labels |
Mon, Feb 8, 2010 at 7:42:35 AM
Upside Dwon Contour Labels drving me nuts |
Tue, Jun 9, 2009 at 2:18:49 AM
Possible to place contour lines to toposurface instead of points? |
Fri, Jun 1, 2018 at 2:57:52 PM
Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing |
Wed, Aug 31, 2011 at 5:29:12 PM
Inverted umbrella column |
Wed, Dec 26, 2012 at 8:12:56 AM
