28 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> new column in schedule
Hi all,
I'd like to add a new column to my area/volume schedule, and be able to write in that column a number (reo tonnage for that floor). I have done this by adding a parameter to the floor, the only issue with this is when i have drawn my floor and then add my number (say for example 6.7) anytime i add a new floor thickness that isn't already in my project, this number disappears unless i apply that same number to the new thickness. Is there a way to add a column in a schedule and then type in a number that isn't assigned to a floor parameter?
If you edit the fields, click "Add a Parameter..." then for "Type of Parameter:" choose "Text", you can then type in anything without affecting other parameters. Choose "Instance" or "Type" for the parameter at your own discression.
Column Schedule |
Mon, Apr 21, 2008 at 7:35:29 AM
Column Schedule Help!!! |
Fri, Feb 20, 2009 at 11:39:39 AM
Crop the Graphical Column Schedule |
Wed, Feb 6, 2013 at 3:29:29 PM
Tagging Graphical Column Schedule |
Wed, Nov 24, 2010 at 8:41:14 PM
Mon, Jun 9, 2014 at 1:43:14 PM
