Forums >> Revit Building >> Technical Support >> Calculated Value - Door Schedule Work Around?
Fri, May 15, 2015 at 12:38:02 PM | Calculated Value - Door Schedule Work Around?
pmoss34
Is it possible to use "calculated value" in the schedule fields for the following end result?:
Our model is currently employing a linked model (which contains the rooms/room separation lines) therefore the door schedule in the main model cannot display the "to room" and "from room" parameters.
Each door number is tagged: "roomnumber.a"      For example a door leading into room N228 is tagged N228.a
Is there a way to use a calculated value to "subtract" the ".a" from the door and therefore give the room number associated with said door?
Fri, May 15, 2015 at 1:03:29 PM | Calculated Value - Door Schedule Work Around?
Sorry - there are no text manipulation formulaes in Revit yet.
Mon, May 18, 2015 at 12:56:02 AM | Calculated Value - Door Schedule Work Around?
ronmalit
5 Stars: 3 Votes
hi pmoss
if you really must... export/import schedule to/from excel. there are plenty of add-ins and workaround out there
in excel use the formuala: =LEFT(text,num_chars)
** dont be mad, i dont have much... i am homeless
Calculated Value in Schedule controling an Instance Parameter
Fri, Jul 19, 2013 at 4:43:25 PM
Calculated totals of formula in schedule
Fri, Sep 11, 2020 at 7:14:07 AM
Adding Dots to the Door Schedule
Fri, Dec 2, 2011 at 5:41:20 PM
Calculated value
Fri, Aug 6, 2010 at 2:17:19 PM
Problem with Door Schedule
Tue, Apr 1, 2014 at 1:49:05 PM
Page generation time: 1.2835
