Forums >> Revit Structure >> Technical Support >> Slab tag positioning
Wed, May 13, 2015 at 5:04:26 PM | Slab tag positioning
gazzalp
Hi all,
I have a family created for our slab tag, and when we first place it on our floor it positions in the middle of the slab (which is fine). However when we edit the boundary of the slab for example to extend the slab, the slab tag moves to the middle of the new boundary outline, which means it now doesnt line up with all the other tags we placed and lined up perfectly. Is there a way to get the slab tag to stay where we originally positioned it untill we physically move it ourselves?
Thu, May 14, 2015 at 8:43:38 AM | Slab tag positioning
Tags always go to the center of the element unless you use free end on your tags.   You can set that before or after placing.
Slab Thickness Tag
Fri, Aug 28, 2009 at 7:16:44 AM
Slab Step Smart Tag
Fri, Aug 2, 2013 at 7:54:38 AM
Positioning the leader on a tag.
Thu, Aug 6, 2015 at 12:16:39 PM
How can I add clear Height (floor to bottom of slab above) in a Room Tag?
Sun, Aug 21, 2016 at 3:08:14 AM
tagging slab level and thickness?
Thu, Jun 4, 2009 at 6:58:43 PM
Page generation time: 0.2342
