21 Users Online (19 Members):
Forums >> Community >> Newbies >> Import from view in Revit 2015
6 Posts No Rating |
Hi,
I have had success using "import from view" in Revit 2013 where all views/sheets appear in the GUI to select from to be imported from a particular project. However in 2015, at least the flavor I'm using, shows some default list that doesn't reflect the actual project. I select the project from file search (which seems different than 2013) and it appears to load but then I get an incomplete list of elements to import. I have views and sheets checked. There isn't that much to check or uncheck in this GUI. In the past, it just worked.
Thanks
This process is for 2D items, legends and schedule setups only. No model view will ever show and as far as I know, no sheets with model views on them.
(2015) import (link) CAD to Revit screened lines (lineweights) |
Wed, Sep 30, 2015 at 2:20:54 PM
Opening a 2015 drawing in Revit 2014 |
Tue, Jul 29, 2014 at 9:11:58 AM
Deleting import symbols |
Thu, May 8, 2008 at 3:14:21 PM
Revit 2015 Templates Not Working Correctly |
Thu, Sep 28, 2017 at 10:53:43 AM
AutoCAD 2015 Lines Scramble when imported into Revit 2015 |
Tue, Jul 7, 2015 at 3:23:06 PM
