Forums >> Revit Building >> Technical Support >> Ceiling grid lines will not show in the "existing" phase
Wed, May 13, 2015 at 11:23:39 AM | Ceiling grid lines will not show in the "existing" phase
pmoss34
The revit file I am working in for some reason will not display the "existing" ceiling grid lines. When I create a ceiling in the current phase, phase, the ceiling hatch shows; but when I switch the ceiling to a previous phase, the hatch dissapears. The ceiling is still there, editable, and lighting fixtures can still host to it. Am I missing something? Any help?
I should note that due to project needs we are using a linked revit file for the rooms. The ceiling is in the central file, but I know display issues can arise from revit links just the same. Any help would be...helpful!
Wed, May 13, 2015 at 12:11:52 PM | Ceiling grid lines will not show in the "existing" phase
They will show if your settings allow it.  Under phasing, look at the graphic overrides settings - existing/patterns.
Wed, May 13, 2015 at 6:05:30 PM | Ceiling grid lines will not show in the "existing" phase
pmoss34
The issue was partially fixed. Under Manage, Phases, Graphic Overrides, Existing-Patterns: the "Visible" check-box was not checked. Of course when you check this box other existing hatch patterns will show up (ie. existing concrete) which can be undesirable in a set where the floor is concrete. This can become confusing when trying to differentiate between new and existing hatches (especially when drawings are re-printed in the field: dark lines can become grey).
Not sure if there is another way to show the existing ceiling grid lines without showing other existing hatches, but there should be.
Thu, May 14, 2015 at 8:14:52 AM | Ceiling grid lines will not show in the "existing" phase
You can add a view filter to turn off the other hatches.
HOW DOES ONE SHOW EXISTING CEILING GRID GRAYED OUT, AND THE NEW CEILING IN BOLD?
Fri, Aug 1, 2008 at 9:38:17 AM
New light fixture blocks out grid lines on DEMO RCP! Anyone know why?
Sat, Aug 2, 2008 at 12:15:05 PM
Reflected Ceiling Plan Phasing problems
Tue, Jun 15, 2010 at 1:03:00 PM
When I copy an "existing" element it reverts back to "new construction."
Mon, Jun 16, 2008 at 2:38:24 PM
Maintaining "Phase Demolished" properties.
Thu, Jun 18, 2015 at 8:19:39 AM
Page generation time: 0.9825
