Forums >> Revit Building >> Tips & Tricks >> FATAL ERROR, REVIT CRASHING
Wed, May 13, 2015 at 3:36:44 AM | FATAL ERROR, REVIT CRASHING
KYLIEBRAITHWAITE
I HAD ISSUES YESTERDAY WITH REVIT CRASHING (15 TIMES IN ONE DAY). THROUGH A METHOD OF TRIAL AND ERROR I WAS ABLE TO WORK OUT WHEN IT CRASHED AND WHY.
A MATERIAL THAT HAD BEEN IN THE PROJECT FOR A LONG TIME HAD BECOME CORRUPT. WHENEVER I TRIED TO DUPLICATE, OR RENAME THE MATERIAL IT WOKRED. UNTIL I HIT SYNC THEN THE FATAL ERROR OCCURRED. I LOST MY WORK AND A SAVE RECOVERY FILE DID NOT SAVE THE MATERIAL RENAME/DUPLICATE.
I JUST THOUGHT I WOULD SHARE THIS EXPERIENCE INCASE ANYONE ELSE HAS A SIMILAR ISSUE. HOPEFULLY IT WILL AVOID A LOT OF HAIR PULLING!
Smile
Tue, Aug 4, 2015 at 4:52:29 AM | FATAL ERROR, REVIT CRASHING
anniesmith
Hi.
The following actions can reduce the frequency of these errors:
  1. Make sure all users have the latest update installed.
  2. Upgrade the graphics card driver to the latest available manufacturer driver.
  3. Disable Hardware Acceleration through Options > Graphics > Graphics Mode.  Un-check "Use hardware Acceleration" (Direct3D®Winking
Thanks,
SD-Academy-Revit
Tue, Sep 15, 2015 at 9:12:22 AM | FATAL ERROR, REVIT CRASHING
BlakeBowman
BlakeBowman Avatar
Probably too high quality objects inside of your project.
Does this sound right?
Blake Bowman
Registered on 9/15/2015
Registered for Taylor Middle School
Fatal error on a shared job Revit 2015
Tue, Mar 15, 2016 at 1:06:32 AM
fatal error
Wed, Aug 30, 2006 at 1:15:22 PM
Fatal error when in any type of sketch mode
Wed, May 16, 2018 at 11:28:43 AM
Fatal Error when adding casework tag
Mon, Apr 6, 2009 at 12:38:40 PM
'Ungroup' causing fatal error in Revit Architecture 2011 [ 1 2 ]
Tue, Aug 24, 2010 at 4:03:21 PM
15
Page generation time: 3.5404
